BONJOUR JE VIEN DACQUERIRE UNE 405 SRI DE 1991 AVEC 162655 KLM ELLE APARTENAI AU PERE DUNE COPINE A MOI JE LES RECUPERE UNE BOUCHE DE PAIN 500 EURO LE JOINT DE CULASSE ET LA DISTRIBE A ETE FAI A 138000 KLM DE CORROSERRI EST EN ASSE BONNE ETAT
EN CE MOMENT JE LUI REFFAI L EMBRAYAGE AVEC LES DEUX CARDAN ET NETAYAGE COMPLET DU MOTEUR RECTIFICATION DES JT QUI FUIT ET JE VAI POUVOIRE COMMENCE A ROULER AVEC JAVAI DEU TROI SOUCI DESSU EM PARTI RESOLU JAVAI UN BRUI DANS LA VENTILATION QUE JAI RESOLUT IL Y AVAI DU PLASTIQUE DANS LE MOTEUR DE VENTILATION BALO JAVAI LES FARE AR QUI FESAI UN PEU GIRLANDE MAI TROUVE CETAI UN MOVAI COMPTACTE AVEC LA PRISE DU FEUX GAUCHE
MAIS LA JAI UN AUTRE SOUCI SES LA LUMIERE DES VITRE ELECTRIQUE AV QUI RESTE ALLUME EN PERMANANCE ET JAI PLUS DECLAIRAGE AU KI JE SES PAS SI CES LA MEME PANNE MAIS LA JE BUCHE POUVE VOU MECLAIRE
[Edit Gigibi] Mise en conformité du titre. Merci d'écrire en minuscules.
